A Augustus Solanus Reputable Mar 9, 2014 1 0 4,510 Mar 9, 2014 #1 How can I create a start disk for Windows XP professional edition in spanish, SP2, from Windows 7 x64 home premium? My OS does not start and can not change the boot sequence!
Solution electronian Mar 10, 2014 If what you need, really, is an (emergency) Repair Disk, you CAN create one from another XP computer, and use it on yours.
hang-the-9 Titan Mar 25, 2010 60,372 1,081 152,940 Mar 10, 2014 #2 You can't, you need the XP disk to run a repair if that is what you are looking for. Why can't you change the boot order? What is the exact issue you are having? Upvote 0 Downvote
electronian Honorable Oct 5, 2012 231 0 10,710 Mar 10, 2014 Solution #3 If what you need, really, is an (emergency) Repair Disk, you CAN create one from another XP computer, and use it on yours. Upvote 0 Downvote Solution
