asp.net machine account problem...
Mercurial
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
my com has 2 accounts, my own and the asp.net account installed by microsoft
..net 1.1 framework...i accidentally set the asp.net account to administrator
and my own default account as limited...so when i logged off and logged in
again...i can only access my default account, which is a limited account. so
how do i change my account back to administrator??
G
Guest
Guest
Hi,
Log on with the builtin Administrator user:
How to Log On to Windows XP If You Forget Your Password or Your
Password Expires
http://support.microsoft.com/default.aspx?scid=kb;EN-US;321305
If you have a password issue, you might try to reset the local
Administrator password with one of the methods mentioned here
(you might need to create the boot cd/floppy on another computer):
http://securityadmin.info/noframes/faqget.asp#password
http://www.petri.co.il/forgot_administrator_password.htm
torgeir, Microsoft MVP Scripting and WMI, Porsgrunn Norway
Administration scripting examples and an ONLINE version of
the 1328 page Scripting Guide:
http://www.microsoft.com/technet/scriptcenter/default.mspx
Mercurial
> Hi,
> Password Expires
before i changed my administrator account into limited, i only saw 3
accounts, one was my own administrator account, one a guest account (which
was off), and the other a password-protected ASP.NET MACHINE account, and
according to wad i have read, it only comes out after i installed the
microsoft .net framework. and i accidentally set the administrative rights on
this asp.net account...but i don't think i saw any built in admin user
G
Guest
Guest
>>Password Expires
Hi,
It is present (it is impossible to delete the builtin Administrator
account). At least for WinXP Home, I think you need to boot into
Safe Mode to see/use it.
Similar threads
