Aspire V keeps shutting down Only when pluged to battery
Goncalo_1
Commendable
May 25, 2016
My Acer Aspire V is working fine then i plug batery and starts to acellarate the fans to the max for no reason and next it shuts down automaticaly for safety!!!! If its acelarated and i remmove the batery plug its slows down and get back to normal!! Why is this happening??
Hi,
Please do try these troubleshooting steps that may help.
- First is to test the AC adapter and battery.
- Remove the battery off the laptop and connect just the AC adapter and see if it will work normally.
- Next is to uninstall/reinstall the battery driver from Device Manager.
- If the same problem will persist while the battery is in that could only mean that it's faulty already.
Hi. I cant remove battery from this computer!!!
