Question Aspiring streamer in need of help
kinghenry101
32
Ok so I just need somebody to tell me whether or not these pieces i picked out are compatible for each other.
MasterBox Lite 3.1 mATX Case with Tempered Glass, DarkMirror Front Panel and External Customization options by Cooler ...
Standard Return Policy
Update
IN STOCK
LIMIT 20
  • $49.99
MOVE TO WISH LIST REMOVE​
Seagate BarraCuda ST2000DM006 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Hard Drive Bare Drive
SquareTrade Protection Plan
  • 3 Year Hard Drive Protection Plan: $9.00
  • 4 Year Hard Drive Protection Plan: $12.00
Recover Your Data
View Details
Update
IN STOCK
LIMIT 100
  • $69.99
  • $59.99
  • Save: 14.29%
JOIN TODAY
MSI B350 TOMAHAWK AM4 AMD B350 SATA 6Gb/s USB 3.1 HDMI ATX AMD Motherboard
  • 3 Year Motherboard Protection Plan: $7.99
  • 4 Year Motherboard Protection Plan: $9.99
Update
IN STOCK
LIMIT 10
  • $99.99
  • $89.99
  • Save: 10.00%
JOIN TODAY
SeaSonic S12II Series S12II 620 Bronze (SS-620GB) 620W Intel ATX 12 V 80 PLUS BRONZE Certified Active PFC Power Supply
  • 3 Year Power Supply Protection Plan: $8.99
  • 4 Year Power Supply Protection Plan: $10.99
Send this item as a gift
Update
IN STOCK
  • $59.99
  • $50.59
  • Save: 15.67%
JOIN TODAY
G.SKILL Flare X (for AMD) 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 2133 (PC4 17000) AMD X370 / B350 / A320 Desktop Memory ...
Update
IN STOCK
  • $79.99
JOIN TODAY
AMD RYZEN 5 1400 4-Core 3.2 GHz (3.4 GHz Turbo) Socket AM4 65W YD1400BBAEBOX Desktop Processor
Replacement Only Return Policy
  • 3 Year CPU Protection Plan: $16.99
  • 4 Year CPU Protection Plan: $22.99
Update
IN STOCK
  • $149.99
JOIN TODAY
XFX Radeon RX 580 GTS Black Edition 1405 MHz OC+, 8GB 256-bit GDDR5, DX12 VR Ready, Double Dissipation, Dual BIOS, PCI-E ...
  • 3 Year VGA Protection Plan: $19.99
  • 4 Year VGA Protection Plan: $26.99
Update
IN STOCK
LIMIT 20
  • $189.99
JOIN TODAY
The total plus taxes is $750 and I can't go a penny higher.
You might want to try using PCPartPicker, which suggests if components might not be compatible.
Right off the bat, I can see some issues though. First, you picked a MicroATX (mATX) case, which won't fit a full-size ATX motherboard like the one in your build.
Also, Ryzen performs best with faster memory, while 2133 is fairly slow by current standards. Moving up to at least DDR4-3000 shouldn't cost much more.
Additionally, the Ryzen 1400 offers 4 mutithreaded cores with integrated graphics, but if you are using a dedicated graphics card you probably won't need the integrated graphics, so you could move up to a 6-core processor without them without paying much more.
kinghenry101
32
Ok. Would this be better?
Yeah, I think that seems better. Going with a 500GB SSD for your boot drive, applications and most played games might be a good idea though. It only costs about $30 more for a 500GB Crucial MX500, which is one of the better SATA SSDs, and has about four times the storage, allowing you to store some games on it to improve their load times. Here's another option I put together based on some changes to your first build. This one relies on some mail in rebates to keep it below $750 though. I also went with a quality, higher efficiency PSU, though that might not be absolutely necessary. And note that Amazon has the Ryzen 2600 for $15 less right now if you are willing to shop around...
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($154.99 @ Amazon)
Motherboard: Gigabyte - B450 AORUS M Micro ATX AM4 Motherboard ($74.99 @ Newegg Business)
Memory: G.Skill - Ripjaws V 16 GB (2 x 8 GB) DDR4-3000 Memory ($94.99 @ Newegg)
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive ($61.99 @ Newegg Business)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive ($59.89 @ OutletPC)
Video Card: XFX - Radeon RX 580 8 GB GTS Black Core Edition Video Card ($189.89 @ OutletPC)
Case: Phanteks - Eclipse P300 Tempered Glass (Black) ATX Mid Tower Case ($49.99 @ Amazon)
Power Supply: SeaSonic - FOCUS Plus Gold 550 W 80+ Gold Certified Fully-Modular ATX Power Supply ($49.99 @ Newegg)
Total: $736.72
Generated by PCPartPicker 2019-03-01 15:27 EST-0500
Edit: And by "shop around" I mainly mean Amazon and Newegg. While OutletPC was included in the PCPartPicker list, I haven't actually bought from them before, and it probably wouldn't be worth the bother to maybe save a few cents.
Especially since the graphics card from them apparently requires a large mail-in rebate to get that price, while that's not needed to get the card for essentially the same price on Newegg.
Also, I would probably go for that Phanteks P300 from your most recent build over the Cooler master one from your first. I only went with that one in my example, since I was roughly basing it on that first build.
Edit Edit: And that edit apparently removed the links, so I posted them again, this time with the Phanteks case.
kinghenry101
32
Total: $736.72
So. I like everything but the price, lol. I was considering upping the ssd to like 500 gb but I just can't push it any further.
this is what I could work it up too. (everything found on Newegg because I'm not trying to have separate orders on different websites)
PCPartPicker part list: https://pcpartpicker.com/list/DZhMtg
Price breakdown by merchant: https://pcpartpicker.com/list/DZhMtg/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($169.99 @ Newegg)
Motherboard: Gigabyte - B450M DS3H Micro ATX AM4 Motherboard ($78.98 @ Newegg)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-2800 Memory ($85.98 @ Newegg)
Storage: ADATA - XPG SX6000 128 GB M.2-2280 Solid State Drive ($30.49 @ Newegg)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Newegg)
Video Card: XFX - Radeon RX 580 8 GB GTS Black Core Edition Video Card ($189.99 @ Newegg)
Case: Phanteks - Eclipse P350X (Black) ATX Mid Tower Case ($53.98 @ Newegg)
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply ($42.98 @ Newegg)
Total: $712.38
Generated by PCPartPicker 2019-03-01 21:57 EST-0500
(I also found it really cool that with the purchase of the Ryzen 5 2600, it would gift me 2 of 3 games, free of charge. The Division 2, Resident Evil 2 or Devil May Cry 5. So that's something)
The final price would be : $810.77... sheesh
Oh yeah, probably tax?
Actually, I think it's the RX 580 that has the offer for the free games from AMD. I believe you get the download codes once the card is installed and you register at their site. It does seem like a pretty nice offer, seeing as those are new and upcoming releases. RE2 was released a little over a month ago, while DMC5 and The Division 2 should be coming out this month.
