Hey guys so i recently build a new gaming pc! Specs are as follows.
Gamemax-w case
8gb (4x2) Corsair Vengeance ram
AsRock 990fx extreme6
Amd Fx-8350 clocked at 4.2 (idle temps 19 degrees 51 under prime95 load)
Corsair h55 water cooler
Msi geforce gtx 970
Gigabyte 550w psu
Crucial 240gb SSD
1tb Hard drive
5 case fans. None on side panel
I am really worried about my Northbridge temps. It idles around 40 degrees, and under prime95 load it shoots up to the mid 70s! Should I be worried? I tried touching it and it's so hot that it burns me if I leave my finger on it for more than a second. If the temps are too high any suggestions on what I should do? Oh yeah, I even removed the heat sink to see if I can put AS5 thermal compound, But instead there was a thermal pad I was worried if I replaced the thermal pad with AS5, It wouldnt make contact with the heatsink, So I decided to leave the pad as is.
Gamemax-w case
Msi geforce gtx 970
Gigabyte 550w psu
Crucial 240gb SSD
1tb Hard drive
