Asrock A320m hdv not setting up DRAM speed?
jdrone411
7
Hi I have this motherboard paired with an A8 9600 Apu and 2x4gb ddr4 that works at 2400mhz
However from the beginning bios reported my ram speed was @ 2133mhz, no setting to change that btw
I did update Bios to the latest version and then Dram "setting" was available to set up.
However now no matter which speed I set my ram, it has no effect, still it is stuck at 2133.
Is this maybe a faulty bios or what?
Thanks..
I have only set ram speed (the only thing bios let me set) but no matter if I put on 1866 or 2600 it will not move from 2133, the other option say something like am4 boot and is on Auto.
So my rams are most likely the problem huh? I would try to test with some friend ram which are from some recognized brand and not like mine, thanks!
These rams were like half the price of the most cheap 2133 "brand" ram, considering the prices of DDR4 at the day, I will not complain at all if they run at 2133 instead of 2400 btw. I tought it was a mobo thing or something like that
