ASrock ab350 PRO4 - How to connect case fan & Speaker?
Mar 20, 2018
16
Dear community.
I ran into a slight issue. I bought an inter-tech case and it comes with a case fan, however I do not know where to plug it on my asrock ab350 pro4 motherboard.
This is an image of the board:
This is an image of the case fan connectors. Do I need some sort of converters to get this working with this motherboard?
My last question is, where exactly do I plug the "speaker" ?
Any help would be greately appriciated.
C++:
Looks like you have everything connected properly.
The leftover cable for the Molex is so that you can connect other peripherals and you don't waste one Molex on a fan.
The connector is a standard 4 pin Molex type, you need to connect it directly to the power supply, there is no connector of that type on your MB.
And I find the speaker to be a annoyance unless I'm troubleshooting ( beep codes ) so I always leave it out.
As a side note: Fans running off the PSU usually run flat out all the time, which may be noisy, if so you can always replace it with any fan of the same size that uses either a standard 4 pin or 3 pin motherboard connector, hook it up to the motherboard Sys_fan header/s and control the speed through BIOS.
Hello.
Thank you for swift response.
So the other cable gets "left" alone for the fan?
As for the speaker situation, if I understood correctly, like this?
