I Incognito_1 Prominent Mar 8, 2017 30 0 530 Jul 2, 2017 #1 Hello, I am looking to get a micro atx am4 motherboard, and I was wanting to know, does the micro atx ASRock AB350M pro 4 have f_usb 1 and 2 headers along with an f_audio header?
Solution rgd1101 Jul 2, 2017 http://www.asrock.com/MB/AMD/AB350M%20Pro4/index.asp#Manual should be in the manual
rgd1101 Don't Moderator Nov 7, 2011 74,856 4,242 176,290 Jul 2, 2017 Solution #2 http://www.asrock.com/MB/AMD/AB350M%20Pro4/index.asp#Manual should be in the manual Upvote 0 Downvote Solution
I Incognito_1 Prominent Mar 8, 2017 30 0 530 Jul 2, 2017 #3 rgd1101 : http://www.asrock.com/MB/AMD/AB350M%20Pro4/index.asp#Manual should be in the manual Thank you, that helps alot Upvote 0 Downvote
