asrock alivenf7g glan audio problem
izerbegovicy
Hy! I have changed my motherboard ,and i only hear the right speaker , the balance is ok , i tried different audio drivers ...if i pull the jack a little i heard them both , but i only can listen music on youtube , if i try a game it says that i don't have a sound card ... Pls help ! I forgot to say that i tried two 2.1 systems , two headphones and one 5.1 ... nothing ... same only right
I tried , i don't have a dedicated sound card , i only have the onboard , and i have the front one from my pc case but those don't work , in front is the one for headphone and one for microphone and in the back i have the onboard thing with 3 slots
I solved a thing , one wire from the front was broken , i replace it and now i have sound from my front , still when i plug in the rear i hear only right , maybe the hole where i plug the jack has something broke ? ( sorry for my poor explanation i'm not expert on english ) when i pull it out a little i hear from both but windows says i don't have plugged jack in rear , front works like a charm , anyway i'm just curious ... what can cause that ...a broken pin inside the hole ... i look with a light and inside looks ok ...
