I am using all three fan headers on the motherboard. Unfortunately, neither from the BIOS or the Fan-tastic software control, can I modify the fan speed.
The BIOS has been update to 1.60, which enables overclocking, but the fan speed does not seem like it can be controlled at all - it is always at 100%. I could disconnect the chassis fan, but I think it is best to keep it running considering that I am overclocking the CPU.
Has anyone found a solution to the fan speed issue with this BIOS version?
Cooler Master Elite 120 Advanced - Mini-ITX Case
AMD Athlon 5350
4GB DDR3 1600 ( OC to 1750MHz)
AMD Athlon 5350
