asrock b250m pro4 cpu temperature
LarryDee
27
Intel g4560+asroc b250m pro4. DeepCool Gamma Archer for cooling. BIOS shows 47-48 C idle. HWmpnitor, speedfan etc. and they showed 27-40. In HWmonitor "t" is jumping from 30 to 40 constantly. Which of them is liying?)
I doubt it's lying. If there is one thing you dont shrug off it's temps. what is your case setup?
oh and did you pull the sticker off of the coolers bottom before you applied paste and installed it?
Old case, everything is cooling fine(2x120 in, 2x120 out), even phenom ii x4 965be worked at 52 max, but under zalman cnps5x. Gamma archer is mounted correctly, checked it earlier =)
