So i had to get an RBG extender cable for my Phanteks Halo's and Phanteks LED light strips. Problem is, the lights for both of the halos, and both of the light strips only shine blue and an almost lavender color. ive messed around with the ASRock Polychrome software, and it only shows those two colors and very slight varients of them, even if i have it on say green or yellow. im thinking i need a BOIS update for it, cause i think that will fix the problem. will it fix it though?
my mobo is the ASRock B450 Pro4
