[SOLVED] Asrock B450m Pro4 Ram Speed Issue
jisgore
47
Hello Guys,
I have built a new Rig with an AsRock B450M Pro 4 Motherboard, Ryzen 5 2600, 16 GB Ram Patriot Viper PV48G320C6K (11D1) which is specifically listed in the Memory QVL for Pinnacle Ridge for this board.
The system runs fine but I can't get the memories to run past 2133mhz, no matter what I do when rebooting after changing the settings to 3000mhz it reverts back to 2133mhz.
I also have a Dominator set of rams and the same happens.
I have tried with 1 stick from both and no luck, can't get past 2133mhz
I have read about Updating the BIOS to fix this but on the AsRock website it says is not recommended to update the Bios with a Pinnacle Ridge CPU. Not sure how accurate is this and if I could do it without issues. Has anyone had any luck updating the BIOS without issue with a Ryzen 5 2600?
If there is anything I can do to fix this issue please, let me know. Thank you in advance.
