[SOLVED] ASRock B550M-ITX/ac low volume w/ headphones?
gjmoran
11
I've installed all the drivers for my PC and having some low volume issues with my headphones plugged directly into the motherboard outputs. Any ideas?
Check in Control Panel > Sound and crank it up as far as possible.
There are also 2 types sound drivers for Realtek.
HDA has Realtek HD sound panel in Control panel and maybe at Taskbar.
UAD (Universal Audio Driver) should also have and universal APP called Realtek Audio console. for further sound controls.
I suggest you start with driver included on DVD that came with MB.
