AsRock Extreme 7+ and PCI-E lanes
kaigen
11
Specifically the Extreme 7+:
This is the PCI-E lane break out for the board:
- 4 x PCI Express 3.0 x16 Slots (PCIE2/PCIE4/PCIE6: single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE4); triple at x8 (PCIE2) / x4 (PCIE4) / x4 (PCIE6). PCIE3: x4 mode)
- 1 x PCI Express 3.0 x1 Slot (PCIE5) (Flexible PCIe)
- 1 x PCI Express 2.0 x1 Slot (PCIE1)
- 1 x Half-size Mini-PCI Express Slot
I have read that the Intel 6700k has 16 pci-e lanes with 4 reserved for storage(source on tom'shardware) I want to sli gpu's then have an NVM-E storage device. sli requires that you have x8/x8 set aside for it to work. then another x4 are needed for the storage making 20, x16 gpu and 4 nvm-e. The question is do AsRock boards support this? I see on the MSI boars that they list it simply as x8/x8/x4 which is misleading as people will think they would be able to use three gpu in CF and get that bandwidth which is actually x8/x4/x4.
Back on topic; the part that makes it unclear is here " PCIE3: x4 mode) " this is listed at the very end by itself, would this be the slot for x4 storage, and be unaffected by sli gpu/ x16 single.
kaigen
11
So the folks on the AsRock forums had this for us:
"The PCIe 3.0 lane specs for the ASRock Extreme7+ look correct to me, due to a new feature of the Z170 chipset.
For the first time the Z170 chipset provides up to 20 PCIe 3.0 lanes. So the PCIE3 slot can provide four PCIe 3.0 lanes independently of the CPU:
http://ark.intel.com/products/90591/Intel-GL82Z170-PCH
This new feature of the Z170 chipset is a significant change, and I'm surprised it is not as well known as it should be IMO.
But I will say that the specs do not make that clear, so I understand why you are asking about this."
Seems to basically confirm what you were just saying there are another x4 pci-e lanes off the chip set.
So the last question is, is "PCIE3" the third slot down on the board or the second like between the two cards?
