Just finished building with ASRock Extreme4 x99 motherboard, Just connected m.2 module to install OS first and an optical drive to boot from first, I went to Boot Options by pressing F2 on startup (startup boots up so quick usually I don't have time to read any of the other options so I just keep pressing F2) in 'BOOT' menu at UEFI (Attaching Photos)
*Please note that I actually physically connected Optical BluRay/DVD Drive on S_SATA3_1 (so I don't know why it is taking 2 First Boot Options with same names; it says S_SATA3_1 and then next one is Listed UEFI;HL-DT-ST I think that's also BluRay Drive?) and then Boot Option #3 it does show "N1-Samsung SSD.."T
Yes I was able to boot from Optical Drive with Win 7 Pro CD, So I thought it will let me choose m.2 drive to create partition and have WIN 7 installed there before I activate after first installation to upgrade to Win 10,
However as you can see in the last Photo Windows DON'T see any physical drives to install itself?
This is my very first time dealing with m.2 module ssd I read that it is better to just have module in there first to install OS and then add other SSD drives for additional drives so that's how I started since I want m.2 to have OS/Programs going forward,
Any input will be appreciated,
Thanks!
Thanks!
