Asrock h170 pro4s vs asrock h170 pro4 vs asrock fatal1ty h170
Naiem111
How good Is overclockable cpu works with an non overclockable motherboard.
From the above mentioned 3 boards, Which motherboard is the best one for an i5 7600k processor.
Thank you.
The i5 7600k will run the same on all of them. If you are not going to get a Z motherboard, don't pay extra for the 7600K. You could save a considerable amount of money by getting the regular 7600.
Two issues:
1- an unlocked K CPU will consume more power than its locked equivalent. And in this case you'd gain a few hundred Mhz while having to pay more for a cooler as well.
2- They're all 100 Series motherboard and since they're superseded by the MB from H270 line, it's almost 100% guaranteed that they will not work with the Kabylake CPU without a manual BIOS update (either at the shop before you bring it home, or at your house with a different Skylake CPU).
*Edit* Downvote me if you like. It still doesn't change the fact that, for example:
ASROCK H170 Pro4: http://www.asrock.com/mb/Intel/H170%20Pro4/?cat=CPU
Only support 7600k with since P7.0 BIOS and with ASROCK already released their H270 series motherboard, there's little incentive for them to produce a H170 board with the updated BIOS to eat into their own sales.
