ASRock H61-DGS with i5 3470 3.2GHz CPU
masemame
46
i need help with the ASRock H61-DGS and i5 3470 3.2 Compatibility. on the ASRock supported CPUs for the ASRock H61-DGS the i5 3470 3.2GHz CPU is not on the list but i5 3470 2.9GHz is. does the ASRock H61-DGS Mobo support the i5 3470 3.2GHz CPU and is there a need for BIOS update. mine is version P1.30
no i was referring to the i5-3470T and i know its LGA1155 but my concern was, why they didn't add it to the supported list while adding the i5-3470T in or maybe i shouldn't be too worry about it, ha?
plus even if it support it but needs BIOS above P1.30 like the i5-3350P(needs version P1.40). i'll screwed.
Buy a cheap CPU to upgrade the BIOS haha - my 3570K didn't work in my board till I updated it either. I ended up buying a cheap 1155 for around $20 USD.
Perhaps keep the extra CPU as a backup for testing when in doubt?
Good News, Assembled it and YA ASRock H61-DGS with i5 3470 3.2GHz CPU are compatible!
Mobo: ASRock H61-DGS
CPU : i5 3470 3.2GHz
GPU : GTX 560SE
RAM : G.SKILL Ripjaws X Series 8GB
