S sudipto1 Commendable Apr 28, 2016 6 0 1,510 May 29, 2016 #1 My H81M-WW have 8pin connector for the cpu. Currently i am using 1x4 pin as my psu have only 1x4pin connector. I gonna buy corsair vs450 which have 2x4 pin connector so do i need to plug both the 4 pin connector or one like now.
Solution alexoiu May 29, 2016 Both 4 pin connectors. However, take into account that the VS series are intended for PCs with low power demands (not gaming).
alexoiu Titan Nov 1, 2012 39,817 250 126,990 May 29, 2016 Solution #2 Both 4 pin connectors. However, take into account that the VS series are intended for PCs with low power demands (not gaming). Upvote 0 Downvote Solution
P Plumboby Respectable Apr 18, 2016 1,079 0 2,660 May 29, 2016 #3 buy a psu with the extra pin to take advantage of powering ur cpu properly Upvote 0 Downvote
S sudipto1 Commendable Apr 28, 2016 6 0 1,510 May 29, 2016 #4 alexoiu : Both 4 pin connectors. However, take into account that the VS series are intended for PCs with low power demands (not gaming). Is antec vp500pc better than the vs series? Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 May 29, 2016 #5 What are the other components and what will the pc be used for? Upvote 0 Downvote
S sudipto1 Commendable Apr 28, 2016 6 0 1,510 May 29, 2016 #6 alexoiu : What are the other components and what will the pc be used for? cpu : i3 4150 ram: corsair 8gb 1600mhz gpu : zotac gtx 750ti hdd; 1 250gb,1 1tb motherboard: asrock h81m-ww i may switch to gtx 950 if the antec psu is enough for it. Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 May 29, 2016 #7 If in US, here's what I'd choose: http://www.newegg.com/Product/Product.aspx?Item=N82E16817207038&cm_re=xfx_psu-_-17-207-038-_-Product Upvote 0 Downvote
