Hi! Sorry if this isn't formatted correctly. I just joined the forums and this is my first build. I'm working on an ASRock Z590M Pro4, and the pump fan connector slots on my board are oriented the wrong way, according to both the manual and the product pictures I looked up online. Everything else has matched up perfectly fine with the manual, and I'm so close to being done with my build.
I'm just not sure what this means. I ordered the board from Newegg and it came in the original packaging, sealed. Is it likely that I received a slightly different model than the Z560M Pro4, or is this a product error? Do I need to submit a ticket to Newegg about this or is it likely to work properly if I just follow the notches as they are? I'm especially nervous because I'm using a 3-pin on a 4-pin slot so the orientation is a little more complicated.
I've attached pictures below, for both proof and reference. Any help would be greatly appreciated!
