ASRock Motherboard Dual Monitor Issue
Jon Larson
I have an ASRock A75 Extreme6 motherboard and I want to use the dual monitor function. This board has one DVI, HDMI and D-Sub port. No matter what configuration option I try, HDMI + DVI or DVI + D-Sub, I am unable to get a display on both monitors. It only allows one at a time. I would really like to be able to use this function, since it is one of the primary purposes I purchased this board.
Specs:
ASRock A75 Extreme6
AMD A8-3870k APU
2 x 4GB Corsair Divergence DDR3 @ 1866 MHz
Has anyone else has a similar issue? Any help would be very much appreciated!
Jon
There are not the same resolution... I wanted to try the setup before i purchased another monitor so I knew that it worked.. I will try to hook my TV via HDMI since that is the same res as my monitor. Will report back soon.
