Asrock n68 vs3 fx Boot Problems
wildey1771
14
hi
i am having someproblems with my asrock n68 vs3 fx with amd fx4100 cpu and 8gb 1600mhz ram.
after biospost i get a flashing cursor for about 20 seconds. How can i fix this.
thanks
on the bios post there is no beep. but when the flashing cursor has gone and windows starts to boot it beeps then also i have reset the cmos and bios. also the bios has been updated successfully and still no change.
would you like a video of this?
run cpu-z under spd tab print it out this is the speed the ram can run. check that the mb is set for the right speed and voltage.
under video devices make sure if your using a add in card that it boots to the add in card first then the onboard video. in staa setting it should be set to ide not raid. there no achi mode on your mb.
