Asrock n68 vs3 fx Graphics Problem
ukgamers
27
Hi Everone
Im doing a cheap build from a friend the spec are below . Il set it all up but nothing is showing on the screen at all. I didnt think that this setup would need a graphics card or am i wrong ? if it dont need a graphics card then what eles could the problem be
19" HTC screen
Galaxy 3 gaming case
Asrock n68 vs3 fx motherboard
fx 4130 cpu
4 gb drr 3 ram
1tb hdd
Many Thanks
Gary
Hi
ok thanks for pointing that out . I think i will change the motherboard to Gigabyte GA-78LMT-USB3
Have you tried this board and Would i need a external graphics card with this board ?
thanks
ok what if i didnt wont it for gaming just surfing the net. would i still need a graphics card with these motherboard and cpu .
then if i did wont it for gaming do you know what the cheapest spec card that will work ok, ive been looking at these
VTX Radeon HD 5450 Graphics Card - 1GB DDR3- PCI Express
1GB HD5450 Sapphire Radeon Pci Express Graphics Card
XFX AMD Radeon HD 5450 1GB Graphics Card
EVGA GF GT 210 1GB DDR3 Graphics Card
Asus GeForce 210 Nvidia Graphics Card
MSI GeForce N210 Nvidia Graphics Card
Palit gt520 2GB graphics card PCI express
radeon hd 4870 x2 graphics card 2gb
VTX Radeon HD 5450 2GB DDR 3 PCI Express Graphics Card - 3.8GB Hyper Memory
VTX Radeon HD 6450 2GB DDR 3 PCI Express Graphics Card - VGA/DVI/HDMI
thanks for all your help i posted my first problem at the top on 4 different forums and you was the only one that give me the correct answer
