Asrock P67 Pro3 and GTX 970
Aug 24, 2018
Hi guys,
I've recently upgrade my core i5 2500k to core i7 2600k, but it seems that my Gigabite GTX 970 (4GB) can't send the visual signal to my Monitor, but the windows can still boot and start as normal. So the question is, are my GTX 970 and the core i7 not compatible with each other, or does it require more electricity to be supplied ?
My PC Specs:
core i5 2500k
Asrock P67 pro 3
GTX 970 4GB
2x8GB DDR3 1600 and 2x4GB DDR3 1333
Corsair VS650 Watt
1TB Hard Drive 7200 RPM + 256 GB SSD Samsung
Thank you for your answers and advices
Asrock has a beta bios that improves PCIE compatibility, maybe give that shot. Install 3.40
https://www.asrock.com/mb/Intel/P67%20Pro3/index.asp#BIOS
