Asrock Taichi code 00 15 30 4c - RAM PROBLEM
Dec 28, 2018
4
Hi there, i just build a new pc and it was running smoothly for about 10 days until today. Dr debug is looping to 00 15 30 4c and the pc it doesnt boot. I removed 1 RAM (B2 position) and it boots!! I ve tried every possible combination and the pc boots only when 1 of my 2 RAMs is installed (doesnt matter which one).
Any ideas ?
My spec:
Mobo:ASROCK s1151 Z370 Taichi 90-MXB5Y0-A0UAYZ
CPU:i7-9700k
GPU:Gigabyte GeForce RTX 2070 Gaming OC
RAM:G.Skill RipjawsV (2x16) 32GB DDR4-3200MHz F4-3200C16D-32GVK
SSD:Samsung SSD 850 EVO MZ-75E1T0B 1TB
Pc was booting ONLY when any of my RAM's was on A2 slot. I reinstalled cpu to check for damaged pins or so and i found nothing unusual.
BUT the PC now boots fine !!!!!
If there was a problem with the CPU why everything was running 100% smoothly for 10 days? What has changed now and the pc boots without issues?
Hi mate, thanx for the fast response you are a treasure !!
Is it possible thermal paste to cause the issue? While i was reinstalling the CPU i cleaned it with a dry cloth, just in case, and i think i saw i tiny bit of a thermal paste underneath.
