I wanted to turn on my case and motherboard just to see how they looked. So I hooked up the fans to the motherboard and a 500w power supply I had from a previous build. Once I plugged up the power switch, 24 pin connector, 8 pin connector along with the fans to the motherboard. I turned the psu on and the less lit up on Thebes motherboard, but when I turned the power button on nothing happened. I made sure the power switch was in the right spot. I know my psu works. I tried jumping it with a screwdriver and nothing happens. I hooked up just the case fans to the fan and did the paper clip trick and the fans and psu came on. Anybody have an idea whats going on ?
