Hi Guys,
So recently I was updating a program called Steam on my computer, and it required for my PC to be rebooted; once it rebooted, it did not show any image on the screen, it was just plain black.
I then decided to restart it myself (manually), however the same problem happened.
I then realized that my motherboard was giving me a Dr. Debug (red code) for d6 and then it changed right away to b0 or 60 (can't tell but I think its a "b" instead of a "6")... and stays there, without showing any image. All the fans are on, and it does not give me any beeping at all.
I remember in the past it would beep if any type of problem happened (such as the VGA not being recognized, it would beep 5 times)
I made sure all the cables are properly plugged in... I tried to boot it with one RAM at a time with every DIMM slot, however still no image. I cleaned the VGA Card, PSU, CPU and put Thermal Paste again, and nothing...
The same red code "b0" (which stands for DXE Core is Started) stays there and nothing happens, it just acts like its booting but does not show me any image 🙁
I've had this rig for 3 years now, and this is very bizarre.
Is there anything I could try to do? Or what do you guys think could be the issue? :/
Specs:
HDD - 1TB Western Digital
SSD -Samsung 850 EVO 120GB 2.5 inch Sata III
CPU- Intel i7 4820K LGA 2011 64 CPU (3.7Ghz 10MB Cache)
CPU Cooling Fan - Corsair Hydro Series H100i
PSU - Corsair Professional Series 860 Watt Digital ATX/EPS Modular 80 PLUS Platinum Power Supply AX860i
GPU - XFX Double D AMD Radeon HD 7870 Black Edition OC 2GB GDDR5
Motherboard - AS Rock LGA2011 Intel X79 DDR3 CrossFirex Motherboard X79 EXTREME 6
RAM Memory - G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000)
Windows 8.1 64 bits
Thank you in advance!
Specs:
Windows 8.1 64 bits
