Review ASRock X870E Taichi Review: Better than X670E, at a lower price
Seriously question: What kind of fans require 36w of power to drive in a desktop configuration?
It's for when you want to plug in 6 fans into the same header for a 360mm radiator in push-pull.
or they figured the user is too dumb and will plug in their AIO pump into the header.
or it was cheaper/simpler to use the same circuit design for both fans and pumps, but then IDK why the CPU fan header only supports 12W.
Reactions: Jame5
Fair enough. I guess I'm officially old now.
I always thought it was bad to try and drive multiple fans from a single fan header. I guess times have changed and they've figured that out. This would also explain how a motherboard could manage and drive one of those fan breakout boards in the new cases I've been looking at. Like this shot from the Be Quiet review last week:
Although looking at it, it has a separate power and mb_sync connection on it. So I really don't understand anything.
Reactions: Why_Me
X870E (versus X670) consumes another PCIE x4 lane for a 40Gig USB4 interface. What can you get that will consume that bandwidth?
A USB hub with 2 x 4K 60 Hz monitors, network, mouse and keyboard.
For more go Thunderbolt 5 with 80Gig.
This isn't a tiny ITX motherboard, so why bother with a dock, unless you are in an unusual situation where you move your desktop machine from location to location on a very regular basis? The majority will plug their stuff directly into the motherboard. If anything, I'd love to see more video cards with USB-C output to handle dual-monitor setups.
Laptops are where most people who need better connectivity will go with a dock, but also because laptops are designed to be portable.
