ASRock z270m-itx/ac will not post brand new build
Oct 13, 2018
I have a AsRock z270m-itx/ac that will not post. Fan spins up just fine, I have slowly removed all components to try and figure out the problem but so far no dice.
At this point its simply the MB and the CPU and the cooler. The CPU is a i7-7700k
Any help is appreciated, thanks
It should also be noted that the motherboard speaker doesnt beep or anything
I have a speaker attached, and after reseating the CPU I got it to do three beeps in a series, so I added the RAM and nothing. Then I tried one ram stick in slot A, nothing, one ram in slot B and Viola, it Posts. But It will not post with any Ram in Slot A. Why is that, Ram is DDR4 Corsair Vengence 2x8GB 2666 MHz, and yes it is listed as compatible.
