asrock z370 and rx580 card issues
datjeeves1234
If i plug in my Asus RX580 and boot up I dont see anything happen. (BIOS has PCIE enabled and IGPU disabled).
I unplug the RX580 and boot into bios via igpu. I set the settings to be igpu enabled and reboot with rx580 connected. I dont see the post but eventually the windows desktop shows up on both monitors. (One plugged into the igpu and the other to the RX580).
I checked all drivers are installed from AMD (17.2.2) and in device manager everything shows OK.
I go to Adobe After Effects to try to select the HW GPU rendering but its greyed out indicating no GPU detected. I reboot with just the RX580 connected and get a blank screen.
Is there any settings on the BIOS I need to check ? Here is my set up"
ASRock Z370 Extreme 4
ASus RX580 8GB
G Skills 32 GB Mem
PSU 620W Seagate Bronze 80+ rated
Windows 10
Adobe CC 2018
