Asrock Z390 and Water pump problems
H4TE
48
Hey guys!
I have the Asrock Z390 Extreme4 and the EVGA CLC 120 AIO RGB cooler.
My problem is if I plug it into CPU_FAN1 the fan and pump won't come on, and the PC turns on for a few seconds and shuts down. If I plug it into CPU_FAN2/W_Pump. The pump comes on, but same result. shut down within a few seconds. If I switch fans, from EVGA to a LED Fan, and run the LED to a LED header on the motherboard and pug the AIO into the CPU_FAN1 header it starts working. I'd like to use the fan that came with the cooler. Any idea how to?
**The fan that came with the cooler works perfectly when plugged into a 4 pin motherboard header.
Similar threads
