Asrock Z390 Extreme 4 & i9-9900K Overclocking
Feb 4, 2019
Hello,
does anyone have experience with this topic? I tried as lot of settings but could not get a stable system. I even don't know how to let the cpu consume more than 150 W. There seems to be a magic border...
Cooling is not an issue because of water cooling.
Thanks
Chris
Feb 4, 2019
Thanks for reply.
CPU-Voltage: I started at 1.3 and increased until 1.38. Because I read about good values around 1.35.
My question specifically relates to the bunch of UEFI-Setting in the OC Tweaker Section:
- Where did you set the 5 Ghz? There are more than place to set frequencies/multipliers.
- Are there any other important changes to be done?
And there is still the 150 Watt border: the cpu throttles down when reaching 150 Watt.
I started about a week ago searching for UEFI settings and found some information from Gigabyte and msi but the Asrock UEFI uses different names/settings.
Thanks,
Chris
