Hi, I'm having a problem with my new motherboard. I'm getting DR Debug code 45 when entering in RAM into the memory slots closest to the CPU, the two outer slots work fine with each stick or ram, and I could put both in the two outer slots and it'll work. Any of them in the inner two, and I get the debug code and the system doesn't POST.
Is this a motherboard problem, a CPU problem or something else and is there any way to fix it other than sending back for a replacement?
It works perfectly with only one stick or both sticks in the two outer slots, and I'm able to boot successfully and have windows installed and am running it fine. I just can't use RAM in dual channel with the inner two not working
