Question ASROCK Z68 pro3 system boots but nothing on monitor please help
malibu200786
Commendable
May 2, 2018
49
So I've been messing around with slight overclocking this is my first time I was watching YouTube on how to do it . And set everything lower than they did to start with.
Motherboard is ASROCK Z68 pro3 with i5 2500k .
I took it 4.2ghz but on burn test was going to past 80oC so stopped it and went down to 4.0ghz .
Everything was working fine . Then Nvidia ask me to update the game ready drivers for my GTX 1050ti which I've done .
When my son was playing GTA 5 it kept crashing the pc .
Then after the 3rd time it won't come back on
also try adjusting the CPU/GPU votage if it is crashing that's normally why PC`s crash after being overclocked.
Thanks for reply but how do I boot in safe mode when nothing comes on the screen ?
I also tried taking graphics card out and plugging VGA to motherboard still didn't work .
I then tried the CMOS jumper and battery still nothing .
What is happening is I press the power button , the fans will spin the led lights on the fans and case will be on the CPU fan and graphics card are spinning . But nothing else happens on the screen , the keyboard lights don't come on or my usb WiFi dongle doesn't light up ?
How can I tell if it's the motherboard what's broke or if its processor?
