Asrock Z77 Extreme4-M vs Asrock Z77 Pro4-M?
Dayle McNeela
355
Ive seen these two motherboards, they look almost the same with a £30 GBP ($45 USD) difference?
What is the difference between these boards?
I plan to overclock my i5 3570K to around 4.4-4.6?
All opinions are most welcome!!
Go for the Pro4 and a good cooler. It should be stable at 4.4 within 1.2-1.25 voltage range.
It can be a bit frustrating to make it stable at 4.5 and 4.6
Ive heard the solid and gold capacitors wont be any different?
I will only be using one GPU... which one would you recommend?
Will this reach 4.5GHz?
Brilliant, cant wait to order this tuesday!
