Hey,
I just installed an Asrock z77 extreme4 motherboard in my PC and i'm having a few weird issues.
Hard Drive detection:
I currently have 4 sata hard drives and a sata DVD drive plugged into the board. Only 2 of these are detected at any given time and it's always the first 2 SATA ports on the board. So, whatever I put into those 2 ports will work and the others won't be detected.
I've tried installing the ASmedia and intel sata drivers, in different orders and one instead of the other, and I managed to get it to detect all of the drives once when uninstall the Asmedia driver and installing the intel one...but after a restart they disappeared again.
Startup power issue:
When I first installed the board it would turn on and off normally. Now i'm having an issue where i'll have to try 10-20 times to get the board to power up using the on-board power button or the case power button. I've taken the board out of the case and still have the same issue....I've tried 2 different power supplies that i've tested with other PC's but it didn't change anything.
So, yeah i'm at a loss, i've never experienced this before with any computer i've built in the past. Should I just get a new board? And if so, what z77 board would you recommend?
Thanks
Thanks
