ASROCK Z77 Extreme4 VS ASROCK Z87 Extreme4 Vs ASROCK Z87M Extreme4
danish123789
19
I want to buy a new motherboard in between ASROCK Z77 Extreme4 VS ASROCK Z87 Extreme4 Vs ASROCK Z87M Extreme4.
My Question is which one to buy. I have a single graphic card XFX 7790. What is the difference between ASROCK Z77 Extreme4 VS ASROCK Z87 Extreme4. Is it worth to buy the Z87. And what is the difference between ASROCK Z87 Extreme4 Vs ASROCK Z87M Extreme4. What does M stand for.
And is ASrock Reliable or should i choose different brand.. Thanks in advance..
Asrock is fine. The Z87 is meant for the 1150 socket, which include CPUs from Haswel line of CPUs, like 4670K for example.
The Z77 is for Ivy bridge, thats the 1155 socket, for CPUs like 3570K.
MAKE SURE which goes with the CPU you choose.
The "M" means it a micro-ATX board, which is smaller and more compact, only use those if they are cheaper or if the case you choose is smaller and does not support full ATX motherbaords.
Hi,
First thing : look at the warranty. If it's under 3 year I would not buy it..
the z77 and z87 is the chipset, usually, the higher the better (to keep it simple) Basically the chipset get match to a cpu and these chipset all allow overclocking (if you have a proper cpu)
The difference between the m and non m is that the non m has more features (surround sound by hdmi, can triple sli/crossfire (instead of 2), 2 more sata ports ect.
http://www.asrock.com/mb/Intel/Z87M%20Extreme4/
http://www.asrock.com/mb/intel/Z87%20Extreme4/
I have intel quad core 2.33Ghz which one i should buy...
I have intel core 2 quad 2.33Ghz. Just now i have seen that my socket size is LGA 775. That means these motherboard will not work with my CPU. ...And thanks for the helpful information.. Is there any motherboard you can suggest me which will fit with the processor.
And one more thing is there any performance different with Socket 1150 and 1155
You have explained it simply...Now i understand.
I was researching a bit and found that Lga 775 is dead. Now i have to buy everything again...:)
Correct. sorry... :)
What is your budget?
Where are you purchasing from?
I am from india... My budget is around rs 12000 for motherboard. That will be 100$. Now the question is i have to buy a new cpu too. So which ghz will be good in core i 5. I want it for medium gaming.
I usually purshase from flipkart.com ..you can search in this site and tell me.
Asrock Z77 Extreme 4 cost Rs 12000. And i think its a good motherboard. My question is. Now i have to buy a new CPU. So which one will be good. Corei5 2nd generation or 3rd Generation. I want for medium gaming. Dont have problem of budget.
