AsRock Z77 Pro4 motherboard VS. ASUS Z77 P8Z77 LK or LE (not sure)
hobojohn512
32
Hey. Are any of the following motherboards any good? I don't need a Z77 motherboard, but I noticed that these came with 8GB of free ram so I realized that I can afford Z77 with these setups. I will be pairing it with a intel i5 3470. Is the Z77 worth it or should I stick with H77? I heard that Z77 will increase the longevity of my build. If there are any H77s or Z77 that are better for about $70 - $80 total, please tell. Also, are these trusted motherboard companies to buy from? What is the difference betweeen the second two?
ASRock Z77 Pro4 LGA 1155 Intel Z77
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157296
ASUS P8Z77-V LK LGA 1155 Intel Z77
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
ASUS P8Z77-V LE LGA 1155 Intel Z77
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131823
