Asrock z87 Pro4, What is Advanced Turbo option in A-Tuning?
debkol35
18
Today, I bought Asrock Z87 Pro4 and i5 4670k
When I went to overclock with A-Tuning, I find these option:-
Advanced Turbo - Advanced Turbo 20, Advanced Turbo 30
What are these options?
I set Turbo 4.0 Ghz from Bios. Do I need to use Advanced Turbo?
http://i61.tinypic.com/2qwg2mu.jpg
umm... under Advanced Turbo, there are two options only.:- Advanced Turbo 20, Advanced Turbo 30
what to do with them?
First, this is ALL the manual says this issue:
Advanced Turbo
You can use this option to increase your system performance. This option appears
only when your CPU supports this function. This option appears only when you
adopt K-Series CPU.
Load Optimized CPU OC Setting
You can use this option to load optimized CPU overclocking setting. Please note
that overclocing may cause damage to your CPU and motherboard. It should be
done at your own risk and expense. This option appears only when you adopt
K-Series CPU.
Load Optimized GPU OC Setting
You can use this option to load optimized GPU overclocking setting. Please note that
overclocing may cause damage to your GPU and motherboard. It should be done at your
own risk and expense. This option appears only when you adopt K-Series CPU.
What I think it means from a few hours of searching (and there is not much), is Advanced Turbo 20 and Advanced Turbo 30 are overclocking of the CPU and GPU by 20% and 30% respectively.
Owner - Asrock Z87 Extreme3 with Intel i7 4770k. I am using setting of Advanced Turbo 30.
