ASRoxk X99 Extreme4 Questions
Matthew-san
886
I plan on upgrading to an X99 board eventually and this one is one of the more affordable ones:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157543&SortField=0&SummaryType=0&PageSize=10&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
I was wondering if this MOBO is compatible with an i5-4690k or if it had the wrong kind of socket? Also, does it come ready with Windows 10 drivers on the driver disc or is that something that I would have to get online. Does this motherboard support two-way or three-way SLI? It's not very specific in the description.
i5 4690k will not work. Completely different platform. You need an i7 5820k, 5930k, or 5960x. You will also need ddr4 memory. It will support 2 way sli with the 5820k, or 3way sli with the 5930k or 5960x.
