Assassin's Creed origins problem
ahsan kenway
Commendable
Oct 5, 2016
36
When I double click assassin's Creed origins icon nothing happens further the game doesn't open please help me, even splash screen doesn't appear
sometimes there can be glitches like that.
To me your spec means you can play the game fairly well. If steam verify doesn't work then it could be a corrupt file. You could try a Windows re-install, it's always good to do once in while anyway. But it's a pain, as you have to re-download everything again. Have you tried re-installing the game. As in removing and doing a fresh download?
If not try that, and then if you've no success you can try the Win re-install. Make sure all drivers are up to date first, GPU/Chipset, BIOS, etc. Rule out the simple things, before a system reset.
