Assassin's Creed revelation lag fix
Kushagra1999
In my computer assassin's creed revelations lags quite frequently
Specs
Processor i3 530 2.9gHz
Ram 4 gb
OS windows 8 64 bit
Graphic Card Nvidia Geforce 610
4gb x1 @ 1333mhz (slow ram speed so get lag) or 2x 2gb @ faster ram speed 2666mhz so no lags . upgrade 1x 4gb ram see the difference . 610 is a good gpu for gaming it dont give lags , after upgrade ram u get the lag change graphics settings in games then try.
GeForce 610 is a very weak entry level graphic card. If you upgrade your card to maybe a gt630/ radeon HD 6670 performance may be slightly pumped; but will not be fluid as your processor is a i3 540 which is again good but entry level
So what are you trying to prove? Where was I wrong in saying that it is a low-end GPU?
