Assembling case problem
xv15tau
15
Hi guys.I have a problem with assembling case. in last community you said that big case better than mini case. i bought a big case and now i cannot assemble it.just problem is power wires(power sw/reset sw/ground+/hdd led and ...).my full system i bought is:
cpu:intel i3 3240
ram:8gb ddr3
vga:1gb gddr5 radeon hd 7790
hdd:1tb
power:green 480 wat
motherboard: asusp8b75-v
please help.
i put other wires true and nothibg is wrong and i almost forgot my case is professional case(deep cool brand).
For the front panel connections (Power SW/Reset SW/Ground+/HDD LED etc.)
You need to look up how to connect them in the motherboard's manual because it's not the same for each motherboard.
Some has it written on the motherboard itself, others you need to refer to the user manuel.
