Assistance with MSI AfterBurner | Fan Control (Not for OverClocking)
Soul Hacker
53
Okay, so I'm not sure where the appropriate place to be ask this would be. I mean, I know there's an overclocking forum but I'm not using MSI AfterBurner to Overclock. I'm using it as a fan controller. If this question would still be better off there, I will happily go ask there instead.
I'm hoping someone with some experience can clarify some things I perceive as wrong here, after thinking I had it set up correctly.
I felt my GPU fans were running extremely hard for temperatures I perceive as low, and I am aware that the lower the temperatures, the better but when the noise is upsetting and you have a fan vibrating .. well, I'm more inclined to let the card get a bit warmer, and run the fans less unless needed.
It was running the fans loud and hard at 63-64'C which was new behavior and not normal, (driver update perhaps?), so I was attempting to gain more normal control over it. (MSI AB claimed the fans were set to roar up to 70% at 60'C by default right now, which is too fast, for too low a temp.)
So onto the issue at hand:
I downloaded and installed it. And did the following here:
In the MAIN INTERFACE that first comes up, upon opening it:
On the FAN SPEED bar: I clicked it and it highlights it and says: User Defined.
I DISABLED [Auto] at the top of the Fan Speed bar. (It seemed if Auto was clicked, it was ignoring the User Defined, *seemed*.)
I clicked Settings.
Selected the Fan Tab.
Enable User Defined software automatic fan control.
I set the nodes' where I want the fan speed to be, compared to the temp.
I set fan speed update period: 10,000 ms. (10 seconds).
Clicked OKAY.
SAVED this to [ 1 ] on the little profile bar.
Clicked APPLY.
It seems now, that no matter how warm the card gets, the fan speeds are not changing .. I think I can hear them getting a biiiit faster, at 70'C or above which .. from my settings, should be 65% and I should hear the fans noticeably at that stage, I believe.
In the progressive graphs on the right:
It says: Fan Speed % | Min: 40 / Max: 40
Fan Tachometer | Min: 1830 / Max: 2010
In the Fan Speed % / User Defined bar, on the left side of the interface, it reads:
(Auto Disabled)
[Min] (SET) ------------------------ [MAX] ( 40) (User Defined)
If I move the (SET) point further toward the max, the fans speed up immediately in response to where I have it set. So I don't want to do that.
EDIT: http://s12.postimg.org/4hv7g3o2j/MSIABIF.jpg
Image provided, because: Clarity.
I left in the description, rather than removing it, just in case the image is too dark for some people or the numbers/text is hard to read on it.
Is this set up correctly, or did I miss something? As I said, the fans SEEM to be remaining at 40% speed, no matter what .. they should spin up and become more audible (but still quieter than they were) and I'm not hearing it .. and that Fan Speed Min/Max keeps displaying 40/40 no matter what.
Is this all correct and normal behavior or did I miss something here?
Thanks in advance for any help, and if you need any clarification, do not hesitate to ask and I will attempt to do so.
post a pic of your fan curve
[Solved]
Part of being a man, is admitting when you've been an idiot .. this is possibly one of those times.
(Auto) has to be turned on.
I think what happened was the settings had not been re-applied, so when I clicked (Auto), what was actually happening was that it was reverting to the GPU's fan settings, since MSI Afterburner's user defined settings had not been applied again, yet, making it appear as though the (Auto) was defying the user defined settings when they just weren't active.
Appreciate the response but I got it. I kind of retraced my process after posting, trying to figure it out myself and ended up doing so.
