Asus 1070 Tubro is at 139 and 405 mhz. Help
zamano251610
Commendable
Sep 19, 2017
31
Is this right? I thought my clocks were much higher. I opened MSI Afterburner and the clock were high for 1 second and then went down to 139 and 405.
I have just reinstalled the drivers and downloaded the ones from Nvidia website. Ran Afterburner and its still saying 139mhz and 405 memory. It jumped a couple of times to highest 1500 or something but then went back to 139 and 405. Why?
Should I ignore it? My Games do not seem to suffer on Max settings.
Help otherwise. Thanks
It is a power saving feature, when the gpu is not needed it lowers its clocks to save energy so you would not end up conusming 130W per hour all teh time, it can go as low as 20W per hour when it is not used.
If you want to test download gpu-z and run the question mark and click on render it will force your card to 90-100% and and your frequency will go up.
I ran GPU Z and rendered it...This is what IU got.
1847 mhz
4006 mhz
