[SOLVED] ASUS 650 wifi Plus doesn't detect my bluetooth game controller ?
Kellerman88
113
6
10,585
Hi.
Just got a new custom build pc with ASUS tuf gaming 650a wifi plus motherboard.
When i try to connect my controller with Bluetooth it won't find it. My phone find it and i have tried two different controllers that we used on my old pc.
Edit: Just found some wifi antennas in the box! Should do the trick when i have time tomorrow :)
Your phone found what? PC? Or the controller?
Also, what result was with the two different controllers?
Did they too found your PC? Meaning you have 3 controllers in total, but only one of them can't find PC?
Thanks for trying to help, it solved by the antenna, i didnt knew it had one that i had to find in the box and screw into the back.
Now it have no Bluetooth problem anymore, i was up until 02 at night researching and tried everything lol
Reactions: Aeacus
