Asus 970 pro gaming aura, vga led is always on. Bios doesn't start
Felipe_24
Hi there, my specifications are: Motherboard Asus 970 pro gaming aura, CPU amd fx 8320 3500 Mhz, Ram Kingstone Ddr3 8gb Pc1866mhz Hyperx Fury Red‎, GPU Asus Radeon R7 370 4GB GDDR5, Power supply Thermaltake 550W (80 plus bronze). In spite of I plugged everything properly, according with motherboard manual, it doesn't boot. Also, Speaker makes one long beep and two short ones and then it repeats the same. The vga led is red, so according to this, we are speaking about a Graphic card problem, but the same graphic card works perfectly in another motherboard, and it is compatible with Mobo Asus pro gaming aura, but I can’t access to the bios.. Please help me…
Your mobo has 2 PCI-E slots. Try the other one. If your VGA card isn't defective, secondary PCI-E slot works and primary doesn't work, your primary will be defective.
VGA LED is the led of motherboard ?
