So I have been using my monitor over VGA. However, recently I decided to switch to dual monitors. Ideally, the monitor I've been using would be running over DVI as the other monitor I found is older and only has VGA in. However, when I have everything set up, only the monitor running over VGA works. I know both work, I've tried switching out the cables, Windows acts like the DVI monitor isn't plugged in, and the DVI monitor gives me a "No Signal" error, not a "Cable Unplugged" error. It doesn't matter whether I have the VGA monitor plugged in or not, the motherboard's DVI out does not work. I was wondering if there was some setting in the BIOS that needed to be changed for DVI or if I need to contact Asus. I have also been considering getting a low-power AMD Radeon R7 240 to configure in dual graphics for the second VGA out.
My system specs:
CPU: AMD A10-7700K
GPU: Onboard Radeon R7
Motherboard: Asus A55BM-A/USB3
RAM: 8Gb G.Skill Sniper 2133MHz
HDD: WD Green 1Tb
OS: Windows 7 Pro 64-Bit
Any and all help will be appreciated.
My system specs:
CPU: AMD A10-7700K
HDD: WD Green 1Tb
