Asus A55BM-E won't post, boot, and CPU fan runs at a high rate
BedermanBen
4
Hello, I've had this motherboard running with my AMD A8 for several months and about two months ago I was just swapping some case fans and all of a sudden it had a warning on my monitor. I can't remember exactly what it was but it would boot and then count down from 10-15 seconds and shut the computer off. I'm not new to building computers because I've built a couple prior to this one, and yes I did ground myself properly. But it had something to do with static. Anyway after a bit it just stopped showing any signal at all. Regardless of using my VGA or DVI ports, it would boot up but would not post, starting booting or anything. Literally it will turn on and do nothing. I'm not really sure as to what to do, I can't get into any bios settings. I was messing with it today and pulled the RAM from the board and still no post or anything. Like I said before, the board will boot up and run but no output. If anyone could give me a hand here I would appreciate it. Thanks.
I can't get into it though. The computer won't boot or allow to me get into my bios. Or maybe I'm not understanding what you mean?
Ok, If you can download HIRENS Software please use it, and check Hard Disk (MHDD) and memory (MemTest). The software are included in HIRENS CD. Please paste in forum results scans Hard Disk and MemTest. Both software you will run with Boot LIVE CD (such as install Windows).
I'm not sure you are understanding me, I get no video output from my motherboard, so being able to test that and run it, I don't have a computer I can go ahead and use to test my hard drive and all that. I'm absolutely sure that my hard drive is fine so there isn't to much to test there.
I'm going to go ahead and try it and see what I can do as far as that goes, I haven't really thought to try that as well, I wouldn't think that the mobo speaker would be going out but honestly I'm willing to try just about everything.
