[SOLVED] Asus AM4 TUF Gaming X570 Plus Wifi vs MSI MPG X570 Gaming Edge Wifi
Sep 5, 2020
19
Which CPU would you recommend if they where both withing your budget.
Ryzen 5 3600X build.
Thank you in advance
I’m big fan of the Asus, I’m looking at this same exact setup. I like Asus x570 like you said it’s newer chipset so longer support for the future. I like the saber tooth features and have had great luck with Asus products
